Greetings to you all.
I just replaced the hard drive and mother board in my A2100 controller ( sent it out and had it done actually). I reinstalled the CPU and connected it all back up as-was.
It runs through the diagnostics no issues and gets to the "loading 2 of 12" message for the machine control and errors as follows:
______________
40-33
Output/Fuse Failure in APC
Rack 0
Cause: A fault condition was detected in one or more of the output devices in APC Rack 0
______________
I have no idea what it means or where to look. Never had an error like that...or any error really other than replacing the hard drive 3 times in the last 10 years. Can someone help me understand what to look for?
I contacted the tech that replaced the mother board and he said that it looked like a bad I/O board and that they hadn't tested it when they ran the motherboard on the simulator before sending it back BUT there was no problem with the I/O board prior...not until after the new MB and HD replacement.
We have no tech service within a couple of hundred miles so I could use some help.
Thank you all in advance.
Kentsui
