Originally Posted by
thewho
I will mill some aluminum with small carbide cutters (<10mm) And I don´t want to be at the spindles max speed all day long. But maybe there is some margin to the 5100rpm
There is some. But the truth is if you want higher rpm you will need to add bearings that are able. The IH spindle would be a good way to go, plus afforable. See if they will sale it wihtout the bearings so you could buy better ones. Getting a spindle to run high RPM is not the easest thing to do, good bearings a must, then the right install, plus break in.
The guys that sale the IH clone would sale you a spindle without the bearings I believe, if IH want. The Tormach you would have to post in the Tormach section to find what the guys are getting for top RPM with the factory bearings. I know some are getting higher, but I am not sure how much.
Jess
GOD Bless, and prayers for all.
