587,086 active members*
2,824 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Can a Gecko 320x control this servo?
Results 1 to 6 of 6
    Jan 2007
    18
    My bridgeport clone with an old (dead) bandit CNC controller has DC servo motors, and I'd like to drive from a Gecko 320X. I realize that I'd need to swap out the encoder.
    1. Will the 320X reliably drive a motor like this?
    stall torque: 400 oz/in
    current continuous: 6.0 A
    max pulse current: 26.0 A
    max volts: 90 v dc
    no load speed: 1500 rpm
    volt. const. Kv: 59 V/KRPM
    2. What type or brand/model encoder would I want to install for use with the 320X? It says that it wants a quadrature encoder with basically TTL outputs. Is there a commonly used & affordable model?
    LKasdorf
    Dec 2003
    24223
    Quote Originally Posted by lkasdorf View Post
    LKasdorf
    Why what encoder resolution is on it now?
    Al.
    Albert E.
    Jan 2007
    18
    Al.
    I've heard from several sources that these old servos used with the bandit controller use analog resolvers rather than digital quadrature encoders needed by Gecko.
    So, I'm trying to determine a good, cheap encoder that will work.
    Apr 2004
    135
    retrofit Bandit servo system with G320X ?
    The G320X can run these servos reasonably well.
    You will need to modify the power supply so that
    you do not exceed the 80 VDC rating of the G320X.
    I would recommend targeting something like 70 VDC.
    This will mean that you will get less top speed, but
    for most users this is not significant. The speed
    reduction will be linear with voltage reduction.
    Most likely your Bandit had relatively low resolution
    encoders on it. I would recommend that you look
    for encoders that yield about 10 counts per 0.001"
    of travel. Too little results in reduced precision,
    too much results in problems generating step pulses
    fast enough and more sensitive PID tuning.
    Many people use programmable resolution encoders
    so they can select the best resolution after installation.
    One such encoder is the AMT-102 sold by Digikey. See:
    http://search.digikey.com/us/en/prod...1307-ND/827015
    They include a kit of shaft adapters to fit most shafts.
    Don't forget to look at cables for them also.
    Regards,
    Steve Stallings
    www.PMDX.com
    Dec 2003
    24223
    It may be best to actually confirm it, it would be a pity to replace something that you could use?
    Al.
    Albert E.
    Jan 2007
    18
    Quote Originally Posted by morestuff View Post
    Digi-Key - 102-1307-ND (Manufacturer - AMT102-V KIT)
    Regards,
    Steve Stallings
    PMDX.COM - Products for CNC and motion control applications
    Thanks for the detailed response, Steve. I have removed the back of one of the motors and observed the tach and resolver, both of which are no longer needed. And, I see where I can install an AMT102 encoder on what looks like a 1/4" shaft. This is all making sense now.
    One thing- these servos seem to be direct drive. I read that most servos have gear reduction, but these do not. How odd is that?
    I think these servos were quite common on bandit installations- I see them in pics of older machines with bandit controllers quite often.
    It is nice to see some sensibly priced components in this area. I spoke with somebody today who was extolling a turnkey fagor retrofit controller for a mere $12k. I couldn't suppress my laughter...
  1. Will A Gecko 320X drive these?
    By Jackal66 in forum Gecko Drives
    Last Post: 11-08-2011, 02:01 AM
  2. Gecko Drive 320X and PIC (STEP)
    By netomx in forum Gecko Drives
    Last Post: 10-03-2011, 05:43 PM
  3. Gecko 320x noise is this normal?
    Last Post: 09-12-2011, 03:45 PM
  4. Trouble testing PMDX 126 with Gecko 320X
    Last Post: 07-24-2011, 05:27 PM
  5. Why use breakout board with Gecko 320X?
    By pp7 in forum Benchtop Machines
    Last Post: 04-18-2011, 08:10 AM
