587,597 active members*
3,766 visitors online*
Results 1 to 7 of 7
    May 2009
    3
    Question Deckel Maho - DMC 63V Z axis drop
    My DMC 63V Z axis drops to the machanical end positon when I hit the enclosure door open switch. Due to which ballscrew bearing clamping bolts shear off or the belt which drives the ballscrew breaks. While running the program this malfunction not observed. It observed when I hit the enclosure door open switch or internal stop switch. It seems that after hitting those switches the motor fourcefully drives the Z axis to the end limit. Power cables and encoder cables are OK. Is the problem is with motor or the drive? Please suggest.
    Thanks...
    Atul
    Aug 2008
    4
    Hai Atul,
    There is from motor Z,that's same problem with my machine also.
    Mar 2010
    You must call to DMG india (Mori seiki). if your machine is from Famot, is necessary to do a retrofit electrical.
    Apr 2002
    5003
    Unfortunately, Its more than 2 Jears ago, until I could answer. Its not a problem of the Motor. The Z-Axis Motor have a magnetbrake. If you close the door, the brake is lifted before the motor get current. That happens, because Deckel have some wrong Circuits in the Control. They know it, but don't say it to their customers.
    Oct 2006
    71
    Re: Deckel Maho - DMC 63V Z axis drop
    Hi, I just picked up a nearly new DMC103v, only 180 hours, loooong story. Everything works great but the z axis will occasionally drop very slowly after estop is pushed at the end of a run before shut down or sometimes during operation if the door open switch is activated. Only happens once in a while and the brake usually kicks in after a few inches of drop. What was the wiring change you indicated you had made? I would like to try it. Thx Mark
    Quote Originally Posted by uli12us View Post
    Jun 2012
    Dear Concern Person,
    We have a machine name is DECKEL MAHO DMC 63V
    TNC 426/430
    HEIDENHAIN
    NC: SOFTWARE
    280475 16
    The problem is that our machine hard disk is dead and not working due to media card problem also our backup is crash and not repairable. We need software in above mentioned machine so that we can buy other hard drive and install it so that our machine will work smoothly.
    Your prompt reply is required in this regard.
    My email address is: [email protected]
    Thanks,
    Adnan Gulzar
    Apr 2022
    3
    Dear all
    I need help please
    Looking for all soft documentation related to DECKEL MAHO DMC63
    Many thanks in advance.
    E-mail : [email protected]
  1. Deckel Maho DMC 63V Z axis intermittent drop.................need help
    By alimansyah in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 11-16-2023, 11:59 PM
  2. deckel maho dmu 50 t
    By gunz in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 12-24-2021, 01:54 PM
  3. Deckel Maho DMU 50 VL
    By waltteris in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 11-13-2016, 09:32 PM
  4. deckel maho mc 800 h z axis home
    By G-off in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 09-28-2012, 09:43 PM
  5. Deckel Maho DMC 75V C axis error
    By vansweiden in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 05-11-2010, 09:03 AM
