587,853 active members*
3,366 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Acramatic 950 Subroutine Repeat ???
Results 1 to 5 of 5
    Jan 2009
    42
    Cannot figger out the coding to repeat a sub on this control.
    Book doesn't mention it at all, and coding for the 900 doesn't work either.
    (CLS, L1, ?xxx)
    R99 does not work.
    The code above without the ?xxx does work, just won't loop.
    Feb 2008
    586
    Re: Acramatic 950 Subroutine Repeat ???
    Have you tried (CLS, L1, 99) where just 99 is the number of repeats?
    Beege
    Jan 2009
    42
    Quote Originally Posted by beege View Post
    Beege
    "Bad Expression"
    Feb 2008
    586
    Is your subroutine local (as in (DFS, L1)~~(ENS) or a separate registered program? A local program should be (CLS, L1, 99) and a separate program would be (CLS, 1, 99) where the "1" would be the program #. I've read that some controls don't support the repeat.
    Jan 2009
    42
    I am running local in this case.
    Really?
    The 900 (10 yrs older) was able to repeat.
    But it wasn't able to run local AFAIK.
    I could try spinning the routine off and calling it that way - and then maybe a repeat will work.
  1. Subroutine
    By Idiod in forum BobCad-Cam
    Last Post: 01-26-2016, 09:16 AM
  2. quick tip: Using Repeat function and proper End Repeat.
    By countryguy in forum Dolphin CAD/CAM
    Last Post: 10-13-2015, 10:42 AM
  3. subroutine
    By kendo in forum Okuma
    Last Post: 01-14-2010, 01:50 PM
  4. Example of a Subroutine?
    By donl517 in forum Fadal
    Last Post: 06-27-2007, 04:05 PM
  5. Need help with subroutine
    By 2_jammer in forum Uncategorised CAM Discussion
    Last Post: 01-18-2005, 05:46 AM
