587,830 active members*
2,821 visitors online*
IndustryArena Forum > CAM Software > Dolphin CAD/CAM > quick tip: Using Repeat function and proper End Repeat.
Results 1 to 2 of 2
    Sep 2013
    326
    Just thought I would add this: In the two images you can see I was trying to run a CAM job on a part to generate 2 sets of Gcode. I am a newb, so there are better way most likely.
    Pic 1: Since I wanted to DRILL and separate that from the Milling portion - I excluded those in the Program Operations.
    It would NOT exclude the Milling parts. Then I just tried moving the "End repeat" above the excluded parts and it works fine.
    Just something for other functions possibly? Exclusions of Program Ops and placement of starting and ending function segments is key.
    Attachment 294752
    Attachment 294754
    Feb 2007
    414
    Re: quick tip: Using Repeat function and proper End Repeat.
    Hello,
    Yes, there is problem with the repeat command working even though an operation has been switched off.
    I'll report it.
    ATB
    Andre
  1. LaserDRW - How Do I Repeat Engraving Function Automatically?
    By makin in forum Laser Control Software
    Last Post: 05-10-2015, 05:14 PM
  2. Repeat
    By cshim in forum G-Code Programing
    Last Post: 08-07-2008, 01:49 PM
  3. incremental repeat function?
    By Joe Miranda in forum Milltronics
    Last Post: 05-21-2008, 04:10 AM
  4. How Do I Repeat?
    By TZ250 in forum Dolphin CAD/CAM
    Last Post: 03-04-2008, 12:11 PM
