587,506 active members*
2,926 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 10T Check System Label Error
Results 1 to 9 of 9
    Sep 2014
    6
    Hi all,
    I have a Cincinnati Milacron ACT 50D plastic mold injection machine with Fanuc Autoshot 10T.
    When we change the battery and turn it on, the screen show this error:
    AUTOSHOT 1A23/01 (90.02.01)
    RAM TEST :END
    ROM TEST :END
    AUX CPU START :END
    LOAD SYSTEM LABEL :END
    CHECK SYSTEM LABEL :ERROR
    IPL MODE
    1 DUMP MEMORY
    2 LOAD/VERIFY
    3 CLEAR FILE
    4 SETTING
    5 TEST
    6 END IPL
    I have all data in another machine but I don't know how to download it to a handy file and then load it into the Cincinnati.
    I've seen some procedures saying at some point to enter "Y" but this machine has only a numeric keyboard.
    Thank you so much for any help in advance!
    Jun 2004
    511
    Re: Fanuc 10T Check System Label Error
    Call Fanuc 1-888-326-8287
    Apr 2009
    1379
    On this control you have to enter '99', press INPUT, enter # of axes and then input your 9900 options in hexadecimal, cycle the power and set up the control to communicate, so you can receive the parameters.
    Sep 2014
    6
    Quote Originally Posted by memoryman View Post
    I haven't had time to check the procedures but, how do I know what values to input for the 9900 options that memoryman said?
    Can I find the 9900 values on the Setting screen?
    This Fanuc control is new to me... I have been looking for the operator's and parameter manuals but I can't still find them.
    Any help you can give me will be great. Thanks!
    Sep 2014
    6
    Thank you both for your answers! I will try with that options.
    Aug 2007
    793
    Fanuc 10 Fanuc 11 Memory Backup Procedures
    I met CD with manuals on eBay
    in future change batteries only under power
    Jun 2018
    8
    Hi
    I have same problem, did you get it fixed??
    i have backup parameters but cant proceed as the machine hasnt got a Y key.
    Sep 2014
    6
    We are not in IPL mode any more. And we are looking the NC and PMC parameter, Do you have those? We can help each other to fix problems.
    Jan 2017
    5
    Quote Originally Posted by rincong View Post
    Hi all,
    RAM TEST :END
    ROM TEST :END
    AUX CPU START :END
    IPL MODE
    1 DUMP MEMORY
    2 LOAD/VERIFY
    3 CLEAR FILE
    4 SETTING
    5 TEST
    6 END IPL
    Did you manage to fix the machine of the parameters and that alarm of the Check System Label? I have the same problem now and I don't have a keyboard to get the Y key
  1. Fanuc 10T system label error
    By Andy Fritz in forum Fanuc
    Last Post: 11-23-2020, 09:48 PM
  2. Fanuc 6T system error
    By salmve in forum Fanuc
    Last Post: 09-10-2020, 07:38 PM
  3. 998 System error on Fanuc 6M
    By david_chen in forum Fanuc
    Last Post: 12-27-2019, 08:18 PM
  4. fanuc 10m Io030 check sum error
    By skippyfix in forum Fanuc
    Last Post: 07-02-2009, 12:52 PM
  5. fanuc 6m has system error 402
    By runlean in forum Fanuc
    Last Post: 01-23-2008, 03:59 PM
