587,768 active members*
3,261 visitors online*
Results 1 to 3 of 3
    Aug 2013
    13
    Laser Pro Mercury 1 Synrad 48-2
    I've got a GCC Laser Pro Mercury machine with a Synrad 25w 48-2 tube installed... When removing it yesterday I noticed that there was a small twin core wire coming from the front of the tube were the beam is produced.
    I'm confused I believed that the large red and black are power wires. The small black BNC wire was the control so what does this other twin core wire do?
    It comes from the front of the tube and does not look what Synrad would install it looks like a mod ? There is a few LEDs in the machine display panel do they control these ?
    I have a standard synrad 48-2 tube I want to replace it with but I don't want to untill I know what this does !
    Any help please regards
    Phil
    Dec 2005
    484
    perhaps a beam shutter switch?
    Jan 2006
    2985
    If there is a shutter, it is most likely as switch as KTP suggested. This switch could be used to disable the laser when the shutter is closed so that you don't blast your shutter with 25W of laser beam.
    It could also be for a red laser beam combiner. The Synrad ones are here: http://www.synrad.com/beamdelivery/1.25%20Series.pdf on page 7.
    It could be an older model or another manufacturer too.
    A picture would most likely solve the mystery.
    Matt
  1. LaserPro Mercury 1 - Synrad 48-2 needed
    By thebigt in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-21-2022, 08:00 PM
  2. Laser table wont lift up (GCC/ Laser Pro Mercury II)
    By aussiemate in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-30-2014, 01:34 PM
  3. Replies: 0
    Last Post: 05-31-2013, 10:29 AM
  4. GCC Mercury Laser having issues.
    By photoguy in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-14-2013, 01:57 PM
  5. Synrad 50 watt laser
    By KTP in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-11-2011, 09:38 AM
