587,935 active members*
4,314 visitors online*
Thread: Hoss 5C 7x10
Page 1 of 2 12
Results 1 to 20 of 23
    Hoss 5C 7x10
    I've been doing some more upgrades to my little Grizzly 7x10 recently so I thought I'd make a thread.
    I've had it for probably 10 years but didn't use it much at all until about 5 years ago (2010) when I decided to convert it to use 5C collets.
    The first thought was to use it on my G0704 kinda like the tormach duality lathe so I started by stripping it apart and cutting down the bed to reduce the height to save some Z axis travel.
    Hoss
    https://www.youtube.com/watch?v=X6OI6xyr7f0
    Attached Thumbnails Attached Thumbnails 042211 005_800x600.jpg   042211 006_800x600.jpg   042211 021_800x600.jpg
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    Re: Hoss 5C 7x10
    This is the start of converting the spindle head to use a 5C spindle from a spin indexer.
    Hoss
    https://www.youtube.com/watch?v=plZClOPxqrk
    Re: Hoss 5C 7x10
    A little more progress made a year later (2011), the arrival of the new G0704 sidetracked this project a bit.
    Hoss
    https://www.youtube.com/watch?v=lz3BRnzINWA
    Jun 2015
    68
    Re: Hoss 5C 7x10
    hey mate, have you got any plans to power the x axis?
    Re: Hoss 5C 7x10
    This is what I made for the collet closer back then, one of the things I'm upgrading this time.
    Hoss
    https://www.youtube.com/watch?v=OifCvOV2XBA
    Re: Hoss 5C 7x10
    I added a simple Z axis dro from some cheap digital calipers.
    Hoss
    https://www.youtube.com/watch?v=N5d4pBcvw3Y
    Attached Thumbnails Attached Thumbnails 051011 004_1000x750_cropped.jpg   051011 007_1000x750_cropped.jpg   022912 001_cropped_618x600.jpg
    Re: Hoss 5C 7x10
    About the last thing I did on this project in 2011 was to turn a 5C blank to fit a 4 inch Shars 3-jaw chuck.
    The lathe fit on the G0704 quite nicely.
    Hoss
    https://www.youtube.com/watch?v=ZXHqqHYTQFs
    Attached Thumbnails Attached Thumbnails 051511 002_800x600.jpg   051511 013_900x1200.jpg
    Re: Hoss 5C 7x10
    It worked pretty well as an attachment on the mill for some CNC turning. Made a simple bracket for the side of the head to hold the tool post.
    I toyed with the idea of using the little rotary 4th axis as a tool turret mounted on the head, never got farther than pictured.
    Hoss
    https://www.youtube.com/watch?v=rriBft6DEBQ
    https://www.youtube.com/watch?v=jrnavyqdtTk
    Attached Thumbnails Attached Thumbnails 052011 003_1000x750.jpg   052011 005_1000x750.jpg   052011 016_cropped_1000x795.jpg   052211 017_800x600.jpg
    Re: Hoss 5C 7x10
    And now some of the newer upgrades.
    I got a better quick change tool post, this 0XA from toolprecision on ebay, it's cheaper than from LMS.
    New List Sale OXA Wedge Type Tool Post Set for 7" x 10 12 14 Hobby Lathe | eBay
    I moved the post stud back about .75 to give more tool clearance.
    I also replaced the middle gib screw in the compound slide with an M4 socket screw to be able to lock it.
    Hoss
    https://www.youtube.com/watch?v=JhFw6oq22eA
    Re: Hoss 5C 7x10
    I made a nice sliding/removable polycarbonate chip guard.
    Hoss
    https://www.youtube.com/watch?v=tATw0bG5S8Y
    Attached Thumbnails Attached Thumbnails DSCN0023_800x600.jpg   DSCN0026_800x600.jpg   DSCN0045_800x600.jpg
    Re: Hoss 5C 7x10
    Bought a full set of 5C collets for the lathe, 1/8 to 1 1/8 by 64ths, 65pcs from CDCO, very nice!
    CDCO Machinery Corp.
    I only had a 1/8ths set.
    Plus I picked up their 72 hole rack for them.
    Hoss
    Attached Thumbnails Attached Thumbnails DSCN0061_800x600.JPG   DSCN0068_800x600.JPG
    Aug 2006
    673
    Re: Hoss 5C 7x10
    As always, looks good. I'm loaning my CNC lathe to my local makerspace, but you've got me thinking about picking up a small 7" to stick on my PM45. Would be nice to be able to run the lathe as a lathe spindle or a 4th axis.
    Re: Hoss 5C 7x10
    Quote Originally Posted by CS900 View Post
    Yes it's nice, I'm contemplating making a nice bigger lathe attachment for the 0704 though the parts will likely just go towards a complete cnc lathe.
    I still have the old lathe attachment I made many moons ago for the X2.
    Projects 5
    Hoss
    Re: Hoss 5C 7x10
    Finished up the Z powerfeed and it works very nice, much nicer than cranking that handle.
    Hoss
    https://www.youtube.com/watch?v=qNCPCt4yVT4
    Aug 2008
    1186
    Re: Hoss 5C 7x10
    Man that is awesome! All of it... I found a harbor freight 7x10 today and picked it up for $100 in perfect working order, guy had it and never used it, still was covered in cosmo protectant.
    The 5C spin indexer idea is excellent. I was just about to order the backing plate from LMS for the 4" 3 jaw chuck I use on the G0704 when I found this mini lathe section and decided to check it out. Now you have me all hot and bothered about doing the 5C spindle.
    Do you have plans for that mod? And which spindle indexer is used? I saw the link to cdco above has one for $48 bucks. Hard to beat if it is the correct one, and I wanted to replace the bearings and go with a belt drive. AC Motor and VFD with spindle index feedback for threading.
    What spindle bore do you have now through the 5C tube? I imagine the 4" chuck has a smaller through hole than the new spindle. Would your 5" G0602 3 jaw fit and what hole size does the 5" chuck have?
    Awesome work! Hoss! I can see having alot of fun with this new small lathe and while it was nice running the G0704. Setup like a lathe, it will be nice having two machines ready to make parts without having to set them up for milling or turning operations.
    Keep the cool stuff coming man can't get enough!
    Chris
    Sent from my XT1080 using Tapatalk
    Aug 2008
    1186
    Re: Hoss 5C 7x10
    Hoss,
    Quick question being you have a g0704 and a mini Lathe, do you think the stock g0704 note and controller would be a good upgrade for the Lathe? I have my stocker and all of its components wrapped up in a box and i started wondering if it might be a bit stronger then the motor that came in the harbor freight mini lathe, anyways, just figured I'd ask the expert!
    Thanks Hoss!
    Re: Hoss 5C 7x10
    yes i planned to do the same, the 704 motor is stronger and has good rpm so it could be geared down with a belt drive for more torque for steel cutting.
    Hoss
    Aug 2008
    1186
    Re: Hoss 5C 7x10
    Awesome! Do you by chance remember what rpm the motor itself spins with the controller?
    Re: Hoss 5C 7x10
    mine was 5500 iirc but it was one of the first ones, don't know what the newer ones are speced for.
    Hoss
    Aug 2008
    1186
    Re: Hoss 5C 7x10
    What do you think would be a good target max rpm would be? I will likely be using slower speeds for bigger 1.5 - 3" parts..
Page 1 of 2 12
  1. Hoss's G0704
    By hoss2006 in forum Benchtop Machines
    Last Post: 03-25-2016, 12:48 AM
  2. Hoss's 3D Printers
    By hoss2006 in forum 3D Printer / 3D Scanner Discussion
    Last Post: 01-27-2015, 04:05 PM
  3. Hoss does it again!
    By tooManyHobbies in forum Benchtop Machines
    Last Post: 11-01-2008, 06:29 AM
  4. Hoss Conversion Well Under Way
    By mrcodewiz in forum Benchtop Machines
    Last Post: 03-31-2008, 09:44 PM
