587,383 active members*
3,637 visitors online*
Results 1 to 4 of 4
    Sep 2006
    5
    Bridgeport EZ Trak DX
    I had the AT power supply fail on our system, this was replaced by an import from the USA, works just fine.
    Then I had a keyboard failure and the only fix for this problem was to replace the Mother board.
    I now have the system up and running but as soon as we try to home the axis they move off on their own.
    The same happens if I go into Jog Mode, I'm not sure if the power supply failure has caused some serious damage.
    Any ideas?
    I would appreciate any help given.
    Jun 2007
    129
    Re: Bridgeport EZ Trak DX
    Sounds like you may still have a keyboard problem. Use an external AT type full keyboard. There are three keyboard plugs on the back of the console. One is for the keyboard on the console and the other 2 are just "pass through" connectors. If you cannot get those figured out, just plug the keyboard directly into the motherboard.
    Sep 2006
    5
    Quote Originally Posted by reabdet21 View Post
    I only have the AT keyboard fitted at present, I have looked at the parameters but I do not know what they are supposed to be!!
    I suspect that I have no control over the analogue output to the drives and they are moving off under a drift?
    Does anybody have a copy of the parameters that are required?
    Jun 2005
    12
    I have a problem with my new At Din 5 Keyboard. The machine loses connection when I transfer the Panel connection from the Key Pad to the AT Din5 keyboard this is a new keyboard from the Factory. It will work tho shugishly if booted with the keyboard in Place.
    The old keyboard worked without having any problems transfering the connections after booting up on the Console Key pad then moving from one Din5 to Din5 connection.
    The papers that come hith the keyboard mention a processor chip. This chip could be causing the problem for the "Hot" transfer of the keyboards.
    Please advise,
    cnctools
  1. Bridgeport EZ Trak Plus
    By reabdet21 in forum Bridgeport / Hardinge Mills
    Last Post: 07-09-2011, 07:27 AM
  2. Bridgeport EZ Trak
    By MarineMachinist in forum Bridgeport / Hardinge Mills
    Last Post: 05-14-2011, 02:29 PM
  3. Bridgeport EZ-TRAK
    By geno in forum Bridgeport / Hardinge Mills
    Last Post: 01-11-2007, 10:31 PM
  4. Bridgeport EZ-TRAK DX-2
    By zukes3140 in forum Bridgeport / Hardinge Mills
    Last Post: 06-21-2005, 03:58 AM
  5. Bridgeport EZ-Trak,to buy or not?
    By BKP3855 in forum Uncategorised MetalWorking Machines
    Last Post: 11-02-2004, 03:45 AM
