587,089 active members*
2,963 visitors online*
Results 1 to 2 of 2
    Jul 2011
    1
    Establishing new part zero
    I have a dilemma establishing a part zero on our Haas mills. For this particular part, we use a "halo" fixture attached to the end of a tombstone to stand up a piece of bar stock and mill from the end. TLOs are measured from the top of this halo. We use a template positioned over a 1/2 EM to move the part around in X and Y until the template is centered then we run the profiling program. On our old Light Machines Benchman mill, I would use G92 X0 Y0 Z0 to establish this new centered point as part 0, to start all milling operations from this point. On our Haas mills, running this line sends the Z axis straight up and it faults out in Z over travel. Thank you in advance for any help offered.
    May 2014
    23
    Re: Establishing new part zero
    Just set one of your offsets as the x and y zero's for this particular setup, and then call that offset in your program or set the machine to be in the right offset and away you go.
    This can be done by positioning the machine where you want XY zero and press "part zero set" for both x and y......just make sure the machine is in the right offset for your setup before running.
  1. RFQ for part to mount on picatinny rail and sheetmetal part
    By JAW in forum RFQ (Request for Quote)
    Last Post: 08-23-2012, 02:00 PM
  2. Newb ? - CAD Part interference & mating part dims
    By pabmartin in forum Mechanical Calculations/Engineering Design
    Last Post: 11-06-2009, 07:18 AM
  3. G-code Establishing a temporary 0,0 from a master 0,0
    By Ingallspw in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-14-2009, 06:10 PM
  4. Re-establishing CS position?
    By jerseyTom in forum Fadal
    Last Post: 08-04-2009, 03:36 PM
  5. re establishing arc
    By bvweld in forum DynaTorch
    Last Post: 09-24-2008, 06:08 AM
