587,108 active members*
3,372 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > help programming radius cent V lathe
Results 1 to 5 of 5
    Dec 2005
    134
    I need help programming some parts with radii's on a lathe with a cent v controller. Can someone help me out?
    Joe
    Attached Files Attached Files
    Jul 2004
    97
    ARE YOU PROGRAMMING WITH CONVERSATIONAL?
    Dec 2005
    134
    Yes conversational.
    Jul 2004
    97
    PROGRAM
    JOE,
    EVENT #1-PROGRAM START
    EVENT #2-MISC-CALL WORK COORD#1
    EVENT #3-TOOL CHANGE OR CALL
    EVENT #4-POS-X4.500 Z0.000 (RAPID)
    EVENT #5-POS-X0.000 (FEED) FACING
    EVENT #6-POS-X4.500 Z.125 (RAPID)
    EVENT #7-TURN RUFF (ENTER VALUES FOR FINISH,RUFF AMOUNT & START POINT, & ETC)
    EVENT #8-LINE X1.470 Z.125
    EVENT #9-LINE Z0.000
    EVENT#10-ARC CCW XCENTER-0.000 ZCENTER-2.250 XEND-4.400 ZEND-(-)1.250
    EVENT#11-LINE Z-2.125
    EVENT#12-END
    HOPE THIS HELPS
    LYN
    Dec 2005
    134
    Thanks Lyn! I will give this a try.
    Joe
  1. programming a radius
    By honda27 in forum G-Code Programing
    Last Post: 10-31-2008, 02:25 PM
  2. From Radius to Diameter Programming
    By metx in forum Fanuc
    Last Post: 04-10-2008, 07:04 PM
  3. Programming a radius
    By fukeneh in forum G-Code Programing
    Last Post: 07-14-2007, 03:35 AM
  4. programming radius/ help needed
    By integrexe410 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-11-2006, 07:14 PM
  5. Programming lathe with radius numbers
    By mudwhump in forum BobCad-Cam
    Last Post: 06-07-2004, 01:14 PM
