587,754 active members*
3,081 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > From Radius to Diameter Programming
Results 1 to 8 of 8
    Aug 2007
    40
    I think my W&S WSU 12 is set fot radius programming. I am used to diameter programming on our Tsugami with a 6T control. The WSU has a 10TF controller. Is there a parameter to change or a code to put in the program? The reason I think it is set up for Radius is that on the x register if I move the slide 1 inch it shows movement of 1 inch not 2" as it should be in diameter programming. Thanks for any help.
    Feb 2008
    586
    Not sure what else has to change, never had to mess with it, but parameter #1006, bit #3 , if 0, radius is specified, if 1, diameter.
    Aug 2007
    40
    Quote Originally Posted by beege View Post
    All bits across param #1006 are 0's. Bit #'s are read from right to left starting w/ 0 correct? 0-7 from R to L ? I need to see if there is any others that need changing also. Thanks. Keith
    Feb 2008
    586
    So change the fourth bit from the right to a one, report back... You know about PWE, yes?
    Aug 2007
    40
    PWE ? Please explain. I am new to this control. Thanks,Keith
    Feb 2008
    586
    Parameter number 8000 (in "settings", MDI) has a bit labeled "PWE" (protect write enable or something). That bit has to be turned on, in settings, in MDI mode. Then, in Service mode, the other parameter is changeable. You should get an alert when you first change PWE, but set it back to zero when you're done, and hit reset, all will be well. I think then you have to power down and restart to make the change effective. But don't forget (write down) what you've changed. This might give you problems, though, if other parameters were written while in radius mode.
    Aug 2007
    40
    I found out that there are other parameters to change also. CMR, DMR and GRD. I can locate CMR @ # 1820 but the others I can't locate. Thanks
    Feb 2008
    586
    It looks like # 1816 , bits 4,5 and 6 adjust DMR (detect multiplying ratio), but i haven't a clue as to what to chance here, and 1850 is "grid shift", which may be what GRD means.. Just looking at the book, don'tcha know.
  1. Haas Control: Radius dimensions instead of diameter
    By Donkey Hotey in forum Haas Lathes
    Last Post: 05-28-2008, 10:17 PM
  2. Programming a radius
    By fukeneh in forum G-Code Programing
    Last Post: 07-14-2007, 03:35 AM
  3. Replies: 1
    Last Post: 02-21-2007, 10:57 PM
  4. programming radius/ help needed
    By integrexe410 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-11-2006, 07:14 PM
  5. VisualTurn diameter v/s radius mode
    By whiteriver in forum Visual Mill
    Last Post: 05-10-2006, 05:56 PM
