587,506 active members*
3,187 visitors online*
Results 1 to 4 of 4
    Mar 2008
    1
    Question EMC2 with PoKeys55 or other USB device
    I am using EMC2 to control my milling machine but need a lot of things to control. I have already run out of my second LPT port pins and realized that I will not have access to the third one :-))
    I found a few I/O boards on the web with many I/O signals that would do the job. The only thing is that I have not found any drivers for these boards for Linux and EMC2.
    One of these is: http://po.labs.googlepages.com/pokeys55
    This thing has driver for Linux but nothing for EMC (nor driver nor hal)
    Does anyone have experience in this thing? If so what would you suggest to use?
    Thanks,
    Adam
    May 2007
    781
    I would likely go with this http://www.mesanet.com/pdf/parallel/5i20ds.pdf.
    Gives you 72 pins and access to a lot of driver cards for real servos (not step/dir) and more.
    Seems to be well supported by EMC.
    Nov 2006
    8
    I do not know EMC2 software.
    PoKeys55 is USB HID device which is supported by almost all operating systems.
    If you are using it as inputs, you can emulate keyboard, joystick or you can runn macros from it.
    If you need it as output, your software (EMC2) should support external software calls. If you can send me some contact for EMC2 developers, we can provide all documentations for direct support.
    regards
    Boris
    www.poscope.com home of PoScope, PoKeys and PoUSB
    Nov 2005
    496
    infor about EMC2: http://www.linuxcnc.org/
    EMC2 wiki: http://wiki.linuxcnc.org/cgi-bin/emcinfo.pl
    developers can be contacted on their mailing list:
    https://lists.sourceforge.net/lists/...emc-developers
    for using Pokeys inputs try using hal_input:
    man page:
    http://www.linuxcnc.org/docs/2.4/htm...l_input.1.html
    wiki pages for using hal_input
    http://wiki.linuxcnc.org/cgi-bin/emc...Remote_Pendant
    http://wiki.linuxcnc.org/cgi-bin/emc...pads_With_EMC2
    Hidcomp surely could control inputs and outputs of Pokeys.
    Hidcomp is not part of EMC but was made for it.
    its a little more complicated. (but more powerful)
    http://hidcomp.sourceforge.net/#hidcompcontrols
    Chris M
  1. CNC optical registration device
    By George Terizis in forum Want To Buy...Need help!
    Last Post: 08-03-2008, 10:13 PM
  2. Unique 'HMI' Device!
    By vacpress in forum Community Club House
    Last Post: 12-22-2007, 05:38 PM
  3. Using a pc as a dro device..
    By hotponyshoes in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-21-2007, 04:58 PM
  4. modbus device
    By Drew in forum Machines running Mach Software
    Last Post: 02-11-2007, 08:59 PM
  5. Need Foam Device Made
    By HIGHtungsten in forum Employment Opportunity
    Last Post: 09-20-2006, 06:08 AM
