587,510 active members*
3,394 visitors online*
Results 1 to 3 of 3
    Jul 2014
    3
    Moshidraw 2014 start position
    The problem I am having is no matter where on the work area I place the object to be engraved it starts engraving at the home position. Does anybody know how to change this without upgrading to a dsp or using different software.
    Its a k40 running moshidraw 2014
    Jun 2014
    611
    Re: Moshidraw 2014 start position
    Hello, this is Nolan from Thunderlaser, can you post some pictures of your software settings and the panel. can you see the "origin" button on panel?
    we use RDC6442G controller not Moshidraw, even though it is different, maybe some function is the same.
    download - Thunderlaser
    Mar 2009
    163
    Yeah... I *think* I had the same problem. My solution was to put a single dot on the bottom right corner of all drawings.
    I *always* put the dot in the same location for all drawings (for me, I put it at X,Y = 10", -9.5" or something). Once the dot is there, the dot defines the bottom-right-corner of a rectangle (and of course, the top-left-corner of the rectangle is the home position).
    Now, I can plop artwork anywhere within that rectangle, and it'll be lasered properly.
  1. Need help with MoshiDRAW (2014.10)
    By slow_rider in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-20-2015, 12:34 PM
  2. Moshidraw 2014 Just stops half wa through
    By jasonb72 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-29-2014, 06:58 PM
  3. Face start position
    By KevinV_MEI in forum Mastercam
    Last Post: 03-15-2013, 11:56 PM
  4. Tool Start position
    By Mike.C in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-17-2008, 03:20 PM
  5. Cut start position in 2d cutting?
    By DennisCNC in forum Visual Mill
    Last Post: 04-04-2008, 04:33 AM
