587,828 active members*
2,980 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Looking for more information about these motors
Results 1 to 4 of 4
    Jan 2005
    24
    I've had 4 of these stepper motors for some time and decided to clean up a little. Before determining whether I keep them or sell them, I wanted more information about them, mainly torque. I'm not sure what application they would be best suited for, while I was thinking of building an engraver or 3D printer.
    They are Vexta Stepper Motors with a gearbox, 2 Phase, 0.1deg / Step, DC 5.7V, 1A - Model #C7463-9212KGM. Physical dimensions - ~2-11/32 square and about 3-3/8" long, ~5/16" shaft.
    I contacted Vexta and was informed that these were proprietary motors and they weren't allowed to give me anymore specific information. Would anyone have any other information regarding them? They have some similar models on their site (orientalmotor) and they start around $133-$300+ but have a higher deg/step. Is it better to have a lower deg/step in terms of resolution? Not sure how resolution is determined. Also, any idea how I can determine the gearbox ratio?
    Thanks,
    Jason
    35538
    Re: Looking for more information about these motors
    Geared motors would usually be a bad choice for a printer or engraver, as the gearbox will typically have some backlash in it.
    Since most steppers are .9° or 1.8° per step, then I'd guess it's either a 9:1 or 18:1 gear ratio.
    They're probably not worth much if you try to sell them, but I'd sell them anyway and just buy the right motors for your application. Steppers are pretty cheap these days.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Jan 2005
    24
    To be honest, I never thought about the possibility of backlash and probably would have proceeded with making another machine. Thank you for that thought, with that, I will just sell them.
    Dec 2003
    24220
    ..Also often the case with the Vexta steppers, any thoughts of removing the G.B. and using them direct is foiled by the spiral gear shaft machined as part of the stepper rotor.
    Al.
    Albert E.
  1. Poll as such on Treadmill motors: Information wanted.
    By Al_The_Man in forum CNC Machine Related Electronics
    Last Post: 02-15-2014, 09:03 PM
  2. need help finding information on Sanyo servo motors
    By zapco in forum Servo Motors / Drives
    Last Post: 05-19-2010, 06:30 AM
  3. Please i need Information on this motors ( KE56KM2 – 039)
    By mmmm in forum Stepper Motors / Drives
    Last Post: 04-12-2010, 09:33 PM
  4. Information about two stepper motors
    By gaga2410 in forum Stepper Motors / Drives
    Last Post: 09-06-2007, 06:13 AM
  5. Information on 6 wire motors
    By pminmo in forum Stepper Motors / Drives
    Last Post: 05-21-2006, 10:35 PM
