587,229 active members*
3,824 visitors online*
Results 1 to 4 of 4
    Jul 2009
    147
    Lathe Diameter or Radius
    Sprut Cam seems to output radius. Mach is in Diameter mode. How do you make these two match? (Duality Lathe)
    Sep 2007
    359
    David welcome to the zone
    Mach3 can work in either mode !
    As for Sprutcam it would be disappointing if both options weren't available.
    Diameter mode is easiest.
    Phil
    Jul 2009
    147
    I did not figure out how to change the mode but they did spend alot of time with me on the phone and got everything worked out. They sent me a new post processer version 15.
    Feb 2006
    992
    Edit Sprutcam post processor ....... force it out in diameter, I never see Sprutcam post but I think one or two number make it output diameter instead radius.
    The best way to learn is trial error.
  1. Are lathe offset values on radius or diameter?
    By sinha_nsit in forum Fanuc
    Last Post: 11-06-2009, 03:46 PM
  2. Haas Control: Radius dimensions instead of diameter
    By Donkey Hotey in forum Haas Lathes
    Last Post: 05-28-2008, 10:17 PM
  3. From Radius to Diameter Programming
    By metx in forum Fanuc
    Last Post: 04-10-2008, 07:04 PM
  4. Replies: 1
    Last Post: 02-21-2007, 10:57 PM
  5. VisualTurn diameter v/s radius mode
    By whiteriver in forum Visual Mill
    Last Post: 05-10-2006, 05:56 PM
