587,490 active members*
3,148 visitors online*
Results 1 to 3 of 3
    Jan 2007
    8
    Post Use of G10 L50 for 11TT fanuc series
    anybody out there know if the command G10 L50 (parameter change) works for fanuc control 11TT series. I tried but didn´t work and I do not if I did something wrong. neither alarm mesasage appeared nor parameter change occured.
    thanks
    Nov 2005
    274
    Quote Originally Posted by marrieche View Post
    thanks
    I believe that is a newer function and is not availible for anything older than 16I.
    Bluesman
    Sep 2006
    2
    Smile G10
    I believe you need to specify what parameter your changing and the value you want to change it to.
    Ex. this is how to load tool radius compensation from the program
    G90 G10 P59 R-.002
    G90 - absolute mode
    G10 - load parameter
    P59 - load to parameter 59
    R-.002 - register value changes to -.002
    hope this helps,
    dave
  1. Fanuc Series O-M DNC question
    By Blu91Z28 in forum Fanuc
    Last Post: 06-30-2006, 05:45 PM
  2. Error L on Fanuc series 10
    By wanchai101 in forum Fanuc
    Last Post: 02-28-2006, 09:09 AM
  3. Fanuc on a Series 2
    By HillBilly in forum Bridgeport / Hardinge Mills
    Last Post: 01-07-2006, 07:50 PM
  4. GN6 Series Fanuc Controller
    By CBMach in forum Fanuc
    Last Post: 08-16-2005, 01:46 AM
  5. Fanuc Series 10
    By kayleesdad in forum Fanuc
    Last Post: 05-09-2005, 08:30 PM
