587,086 active members*
2,831 visitors online*
Results 1 to 2 of 2
    Oct 2003
    593
    Home switch position
    I'm now thinking about adding home and limit switches to my machine. I want X/Y home, to be at table centre 0,0. Z=top of travel.
    When cutting a toolpath the machine would continually trigger the home switches at 0,0. Is this trigger ignored unless you've told the machine to goto home position.
    Thanks.
    Regards Terry.....
    35538
    Home switches are typically only active while the machine is commanded to the home position. During actual cutting, they should have no effect. Some controllers allow you to configure switches as both home and limit switches. This would not work for your application. Many people home their machines at the center, and then have limit switches at the ends.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  1. home switch
    By zoltan in forum DIY CNC Router Table Machines
    Last Post: 06-09-2005, 07:48 PM
  2. photomicro sensor, ~$25. Will this work for home switch?
    By spoiledbrat in forum CNC Machine Related Electronics
    Last Post: 05-29-2005, 03:14 PM
  3. Dirction / Step lines!
    By bigal in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-06-2005, 08:51 PM
  4. Limit Switch / Home Switch in Software
    By Sanghera in forum CNC Machine Related Electronics
    Last Post: 11-02-2004, 12:58 AM
  5. Limit & Home Switch set-up
    By andybuch in forum DIY CNC Router Table Machines
    Last Post: 06-20-2003, 05:39 PM
