587,326 active members*
3,467 visitors online*
Results 1 to 2 of 2
    Apr 2003
    16
    Question Limit & Home Switch set-up
    I need so help??
    How do I set-up the home & limit switches on the same end of an axis. I using the DeskCNC card with Gecko Drives. I know (I think) I do not want the trip the limit switch when I homing the machine. A diagram would be great
    Andy
    Andy Buchholz
    www.easternshoresigns.com
    2139
    Put the home switch where you want the home position to be located. let's say for the x-axis it's the left hand side at 0. Put the overtravel limit switch at the extreme left just before the mechanical maximum negative travel. This could be at -.5" or whatever. If there isn't enough room, you could stack the switches on top of each other and have them staggered just a little so the overtravel switch isn't hit when homing.
    Eric
    I wish it wouldn't crash.
  1. Home and Limit Switches
    By itsme in forum CNC Machine Related Electronics
    Last Post: 02-20-2005, 02:16 PM
  2. Dirction / Step lines!
    By bigal in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-06-2005, 08:51 PM
  3. Limit Switch / Home Switch in Software
    By Sanghera in forum CNC Machine Related Electronics
    Last Post: 11-02-2004, 12:58 AM
  4. Limit switches and home switches
    By viktorcnc in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-03-2004, 12:11 PM
  5. Limit Switches
    By Mr.Chips in forum Xylotex
    Last Post: 02-25-2004, 04:13 AM
