587,546 active members*
3,428 visitors online*
Results 1 to 12 of 12
    Mar 2019
    94
    An easy one, g54
    I’m learning on my Fanuc 21 mill. Trying to do a simple go to the work piece with g54 then from that position move on the x axis 4.0 inches. When I input it in Mdi and tried it several ways it keep traveling at an angle right from the start, doesn’t rapid to g54 then travel the 4 inches along the Z
    Could it be parameter 1401.1 is set wrong?
    Craig
    Re: An easy one, g54
    This should help explain it
    Dec 2013
    5716
    Maybe this would work
    G54
    G0 Xn.nnn Yn.nnn
    G1 Zn.nnn Fn.n
    Jim Dawson
    Sandy, Oregon, USA
    Mar 2019
    94
    An easy one, g54
    Still moves at an angle from the home position
    Dec 2013
    5716
    Normally making a G0 move, each axis moves independently and simultaneously, taking the shortest path to the assigned position which may be at an angle depending on the starting and ending position.
    If you want the X and Y to rapid along a specific path, then you would really need to make a G1 move at a high feed rate.
    Jim Dawson
    Sandy, Oregon, USA
    Mar 2019
    94
    It does work, goes to g54 then the x axis but it’s all rapid thru the z too
    Quote Originally Posted by Se5a View Post
    You can NOT have a rapid (G00) and a feed (G01) in the same block. Fanuc only looks at one or the other as you can not do both.
    Dec 2013
    5716
    In your screenshot above, I would expect the table to rapid to position at X-4.0 and Y0.0, then the Z would move down to 0 at 50 IPM.
    Jim Dawson
    Sandy, Oregon, USA
    Mar 2019
    94
    Right now I want to leave Z out of any movement until I get it figured out.
    I’m just trying to mill a key way in a bar
    Dec 2013
    5716
    I think what you want is this
    G54
    G0 X0.0 Y0.0
    G1 Z0.0 F5.0
    G1 X-4.0
    Jim Dawson
    Sandy, Oregon, USA
    Mar 2019
    94
    Bingo! You win a case of beer! Worked perfect
    Dec 2013
    5716
    Happy I could help :cheers:
    Jim Dawson
    Sandy, Oregon, USA
  1. New guy go easy
    By Beachcues in forum DIY CNC Router Table Machines
    Last Post: 04-23-2014, 06:57 PM
  2. MC Art has got to be easy, right?
    By dfearnow in forum Mastercam
    Last Post: 03-11-2014, 11:36 AM
  3. Easy cnc
    By purecnc in forum DIY CNC Router Table Machines
    Last Post: 10-14-2012, 05:41 AM
  4. MastercamX not so easy with easy projects
    By X7racer in forum Mastercam
    Last Post: 05-22-2008, 03:28 AM
  5. Easy CNC and Easy Stepp'n
    By kylecroft in forum Community Club House
    Last Post: 02-18-2007, 06:54 PM
