Originally Posted by
handlewanker
I have a set of Metric ER 32 collets and also a number of Imperial endmills and slot drills, and when the shank size is 3/4", it means you have to go to a 20mm collet and squeeze it down to 19.05mm, which it is designed to do, but as it's rather extreme, I invested in a set of imperial collets to offset the problem.
Ian.
If it's pull out, this is probably the cause of it.
You'd be surprised how much thrust a high helix endmill will exert. I've had bigger endmills pull out of R8 and TG100 collets before too.
Wizard, if he wants to build a smaller machine than the one I suggested, I say go for it. I'd probably have a use for it too, but I could really use a machine of the size I noted before.
Got any links to what's available already? I've been looking for a while now, and coming up pretty much empty. Nothing but quasi-CNC flat bed conversions from China and India.
I could use a slant bed big enough to get rifle barrels inside, but I don't have $60k to drop on a used machine that's 20 yrs old.
Ryan Shanks - Logic Industries LLC
http://www.logic-industries.com
