587,357 active members*
3,708 visitors online*
    May 2005
    90
    Shoulder Mill Help
    Hi there,
    I have a question - I'm not an experienced operator, but landed myself a Bridgeport Series 2 Interact 2 and just finished retrofitting the machine with an AJAX/Centroid Control. Now I get to learn how to use the machine. I need to mill a couple of deep aluminum pockets (3" deep) and have a Sandvik RA390 Long Shoulder Mill. The cutting diameter is the same as the shank dia, and the tool is about 8" long overall. If I run the tool down into the pocket wherein the shank is in the pocket and running along the sides - is that bad? - or should I pick up a tool where the shank has a smaller dia than the cutting dia.
    Jay
    Dec 2013
    5716
    Re: Shoulder Mill Help
    I have done that, but I don't like to. I have relieved the shank on the endmill, just used a bench grinder to do that. Only takes a few thousandths to have enough clearance.
    May 2005
    90
    Thanks Jim - sounds like a plan - I'll throw it into a mill and skim off a smidgen.
    Jay
  1. HAAS TM3/Kennametal shoulder mill issues
    By jbifs in forum CNC Tooling
    Last Post: 10-14-2015, 03:10 AM
  2. Code to mill shoulder with C-axis?
    By mstevens in forum Uncategorised CAM Discussion
    Last Post: 11-06-2012, 03:49 AM
  3. Square shoulder end mill efficiency!?
    By zaebis in forum MetalWork Discussion
    Last Post: 09-09-2009, 03:29 AM
  4. Replies: 16
    Last Post: 07-24-2008, 02:34 PM
