587,768 active members*
3,290 visitors online*
Results 1 to 6 of 6
Hybrid View
    Jun 2013
    5
    Shoulder chamfering?
    This isn't a Tormach specific question, but since the community here is nice and it's the machine we've got I decided to post here. We have a part that we need to machine with a chamfered shoulder (see attached picture, the chamfer is some 5mm tall). When we had the part done outside, the contractor would run a regular endmill in various steps as to simulate the chamfer, giving us a staircase-like jagged effect. Since this chamfer is there mainly for cosmetic purposes and we now have a Tormach at our disposal, we want to do it right. I've never used a zero-point chamfering tool before, but I'm assuming the zero-point actually has some actual physical dimension that would prevent the bottom surface from being perfect after the chamfering operation.
    Any suggestions on how to proceed?
    Feb 2006
    7063
    If it's a 45-degree angle, you could do it with a 90-degree spotting drill, making two or more passes to cover the entire chamfer area.
    Regards,
    Ray L.
    Jan 2012
    714
    If its just cosmetic, you could use a radiused corner endmill, I dont know what the correct terminology is for it.
    Depending on the part the whole pocket could be machined with it.
    mike sr
    Dec 2010
    1230
    Ball nose end mill. Much easier.
    Brian
    WOT Designs
    Mar 2009
    1863
    Can you give a better discription of the part? Is it a straight wall? Is it in the bottom of a pocket? Is it on an island where you cut all around the part?
    There are lots of people who can help you here, but the discription you have given is rather vague.
    Apr 2013
    1788
    If I understand correctly you want a chamfer on the inside corner between a vertical and horizontal edge. I believe that the cutter you need is called a bull nose end mill. These are available as normal mills and with inserts. Google for lots of photos and manufacturers. See HSMWorks for a picture. As one example of one using inserts see Bull Nose End Mills ? KDMT
  1. Lathe - Gouging at shoulder?
    By Ashley Cobb in forum MetalWork Discussion
    Last Post: 12-20-2012, 03:41 AM
  2. Al. shoulder shims
    By Slim1 in forum Employment Opportunity
    Last Post: 01-07-2009, 11:59 AM
  3. Threading right up to a shoulder - ideas?
    By SRT Mike in forum MetalWork Discussion
    Last Post: 07-18-2008, 08:43 PM
  4. rotary shoulder connections on TL-3
    By alain aleman in forum Haas Mills
    Last Post: 02-18-2007, 06:38 PM
  5. RFQ - Aluminum Shoulder Screws.
    By Spitlebug in forum Employment Opportunity
    Last Post: 05-17-2006, 10:49 PM
