586,588 active members*
2,563 visitors online*
IndustryArena Forum > MetalWorking Machines > Shopmaster/Shoptask
IndustryArena Forum: Shopmaster/Shoptask
Page 11 of 30 91011121321
Threads 201 to 220 of 599
Discuss Shopmaster/Shoptask machinery here!
  1. Running VFD under Mach3
    Started by jlmccuan, 09-04-2014 11:57 PM
    art, changed, command, fine, frequency, ideas, mach, mach3, manually, motor, parameters, run, running, send, set, set up, shows, stabilizing, star, start, trouble, vfd
    09-13-2014, 07:05 PM Go to last post
  2. Air jets added under quill.
    Started by julian wilson, 09-04-2014 03:41 PM
    adjust, air, art, bolts, bridge, cad, control, copper, cut, cutting, fluid, machine, mist, post, power, power supply, pump, quill, slot, star, supply, switch, tool, welding
    09-10-2014, 10:19 PM Go to last post
  3. QCTP on the Shoptask
    Started by Tom488, 09-01-2014 04:42 PM
    09-04-2014, 08:12 PM Go to last post
  4. Shoptask 1720 gold three phase conversion
    Started by tgorsuch, 08-10-2014 03:16 AM
    170, conversion, fm50, gold, motors, mounting, order, ordering, phase, plan, planning, purchase, ready, rpm, shaft, shop, shoptask, spec, teco, thoughts, three phase, version
    09-04-2014, 12:44 PM Go to last post
  5. Fix for Patriot leaking spindle seal
    Started by Tom488, 08-12-2014 08:25 AM
    08-30-2014, 01:46 PM Go to last post
  6. Patriot PDF's
    Started by jlmccuan, 08-22-2014 09:53 PM
    ces, cnc, cnc machines, control, couple, differences, documentation, functions, how much, level, machine, machines, patriot, pdf, pdfs, send, serial, set, set up, spindle, spindle control, vfd
    08-29-2014, 07:10 PM Go to last post
  7. Increase Mill Spindle to Support Column Clearance
    Started by jlmccuan, 08-19-2014 02:54 AM
    block, bought, bridge, clearance, cnc, column, crease, half, increase, make, mill, part, patriot, pictures, spindle, support, surface, table, vfd, week, wires, work
    08-21-2014, 01:13 AM Go to last post
  8. Making some nice things on my Patriot.
    Started by julian wilson, 08-04-2014 02:17 PM
    151, 622, adjust, art, assembly, box, cycle, fuel, fuel injection, ice, injection, machine, machining, made, milling, motor, nice, posting, replacement, sheet, star, steel, tech, tool, tramming
    08-04-2014, 03:31 PM Go to last post
  9. Shopmaster VFD Homing issues.
    Started by usalfa, 06-25-2014 10:54 PM
    06-25-2014, 10:54 PM Go to last post
  10. Setting up WJ200 VFD w/ Shopmaster .
    Started by countryguy, 05-08-2014 07:00 PM
    application, automation, code, cost, data, environment, erp, gage, head, logging, machining, offer, pci, product, resource, review, ring, script, services, special, string, student, vfd, website, wj200 vfd forward reverse
    05-24-2014, 03:34 PM Go to last post
  11. Issues with Shopmaster owners
    Started by TeaManMachine, 01-25-2012 12:40 AM
    4 Pages
    1 2 3 4
    05-18-2014, 05:16 AM Go to last post
  12. A Remedy for table twist
    Started by wormwood, 08-29-2013 07:47 PM
    rough
    05-04-2014, 08:24 PM Go to last post
    05-01-2014, 06:17 AM Go to last post
  13. Mach 3 has some CAM Wizard and CAM add-on packs
    Started by countryguy, 04-30-2014 03:00 AM
    ..., cam, dolphin, easy, feedback, general, hobby, long, mach, mach 3, mach3, mill, needed, offer, posting, project, questions, review, screen, setup, software, star, time, wizard, work
    04-30-2014, 03:00 AM Go to last post
  14. Shopmaster Patriot VFD Owners, Your Thoughts?
    Started by jbaz, 04-22-2014 09:17 AM
    04-25-2014, 09:14 AM Go to last post
  15. Optical Lathe RPM Opto equiv
    Started by countryguy, 04-23-2014 07:05 PM
    163, 167, belt, buy, chuck, combo, lathe, lathe chuck, mach, mach 3, mill, optical, output, patriot, product, retention, rpm, sensor, series, setup, transistor, update, wanted, wheel, wires
    04-23-2014, 08:37 PM Go to last post
    04-21-2014, 07:54 PM Go to last post
  16. Trumph 3030 L20
    Started by SJ74, 04-21-2014 07:49 PM
    buying, convert, directory, drivers, dxf, issues, laser, lasers, limits, load, lst, nes, nesting, nesting software, operator, operators, parts, post, short, site, software, tech, touch, trumpf, work
    04-21-2014, 07:49 PM Go to last post
  17. Mill Table Drive
    Started by dogboy, 02-02-2014 03:45 PM
    02-10-2014, 01:53 AM Go to last post
    01-29-2014, 08:54 AM Go to last post
Forum Information and Options
Users Browsing this Forum
There are currently 2 users browsing this forum. (0 members & 2 guests)
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
