I'm building the standard 4848.
In the tips and tricks on their website, it says to use shims between the riser and the gantry to shim for square.
I checked my base and table after assembling them and they were only 1/16" out of square. After mounting the
gantry. I've checked and it is square to the base and rails. However, there is a 1/2" difference between the bumpers,
side to side, at the front and back of the base. I shimmed it to the maximum the bolts will allow and still have a 3/8" difference.
Any suggestions to remedy this? Or is it even a problem if the gantry is square?
