586,556 active members*
3,326 visitors online*
IndustryArena Forum: Sharp CNC
Page 2 of 7 1234
Threads 21 to 40 of 125
Discuss Sharp CNC machines here.
  1. Machine treats feed as rapid after tapping
    Started by MGA01, 12-02-2012 09:43 PM
    away, spindle setting, then
    07-01-2017, 05:48 AM Go to last post
  2. Tool Changer out of sequence Fanuc Oi-MC Control
    Started by ren3600, 01-13-2016 11:26 PM
    carousel, match, number, pocket, tool
    07-01-2017, 05:12 AM Go to last post
  3. SV2412S Tool Carousel is Posessed
    Started by JarrettP, 04-06-2016 06:41 PM
    carousel, machine, power, sv2412s, tool
    07-01-2017, 05:05 AM Go to last post
  4. Post SV2412 M-code for Chip Auger
    Started by dpetit28, 01-12-2015 05:54 PM
    auger, chip, chip auger, chip conveyor, code, hi all, m-code, machine, question, said, sharp, sta, standard, sv2412
    07-06-2016, 07:05 AM Go to last post
  5. tool magazine won't go forward
    Started by mcv, 07-01-2016 02:19 PM
    airhose, forward, magazine, manual, tool
    07-05-2016, 03:27 PM Go to last post
  6. How setting tools and setting offset
    Started by John246, 03-15-2010 04:56 PM
    everyone
    04-09-2016, 08:31 PM Go to last post
    03-01-2016, 12:03 AM Go to last post
  7. Coolant foaming problem
    Started by Larry Myers, 10-09-2007 11:51 PM
    2 Pages
    1 2
    mos
    01-26-2016, 09:55 PM Go to last post
  8. Having Problems when Z axis is referencing home
    Started by 72volvo145, 08-14-2015 12:40 AM
    axis, day, issue, mill, night
    08-21-2015, 04:27 AM Go to last post
  9. Question Memory Card Error 99 SV2412s
    Started by 72volvo145, 01-11-2015 10:38 PM
    card, controller, memory, setting, sharp
    08-14-2015, 12:31 AM Go to last post
  10. Thoughts on a Sharp 2416?
    Started by Harbor, 07-17-2014 12:41 AM
    01-13-2015, 04:24 AM Go to last post
  11. sv-2412 spindle parameters
    Started by wallygator63, 01-05-2015 08:19 PM
    200, 412, 60devious, 60rpm, devious, ers, locking, parameter, parameters, pas, past, rpm, runs, set, spi, spindle
    01-05-2015, 08:19 PM Go to last post
  12. Sharp retrofit CNC mill problems
    Started by Stephen Samuels, 06-18-2014 10:47 PM
    110, anilam, axis, board, cnc, cnc mill, delay, gage, inches, issues, knee, knee mill, limit, mill, motion, problem, problems, rapid, retrofit, servos, system, table, turn, wait, work
    06-18-2014, 10:47 PM Go to last post
    04-07-2014, 03:57 AM Go to last post
  13. spindle chiller ?
    Started by D.D.Machine, 03-13-2014 04:14 AM
    chiller, chillers, hours, jobs, open, rpm, run, running, spindle, time, work
    03-17-2014, 05:34 AM Go to last post
  14. need 2412 SRAM files
    Started by spock, 02-20-2014 02:37 PM
    alarm, backlash, backup, change, control, copy, corrupted, dead, fanuc, files, laptop, macros, memory, mill, mini, mini mill, parameters, punch, punch out, reload, reset, scan, sram, tool, tool change
    02-20-2014, 02:37 PM Go to last post
  15. Spindle orientation fail
    Started by mcv300, 12-04-2013 03:01 PM
    12-04-2013, 03:01 PM Go to last post
    11-07-2013, 04:34 AM Go to last post
  16. Exclamation SHarp 6335A with Oi-MD; DNC Memory Card problem
    Started by HRM, 09-29-2013 12:15 AM
    10-19-2013, 12:34 AM Go to last post
    08-16-2013, 09:53 PM Go to last post
Page 2 of 7 1234
Forum Information and Options
Users Browsing this Forum
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
