587,560 active members*
3,289 visitors online*
IndustryArena Forum > CAM Software > MadCAM > setup for tilted 4th axis in MADCAM
Results 1 to 2 of 2
    Apr 2018
    14
    Folks: I am trying to set up a 4th axis (rotary) in MADCAM. I can set one up with the rotation axis aligned with the X or Y axis. I need to set up a rotary axis that is tilted about Y toward the positive X axis by 5 degrees. I need this to cut the sides of elliptical cylindrical boxes that have curved inside and outside surfaces. If the sides were straight I could just use the X, Y, and z axes. I can set the tilted axis up using 4 axis or 5 axis setup in MADCAM and choose the rotary axis in the simultaneous 4 axis dialog box. However, when I do that the rotary clipping planes are very weird, extending many times beyond the z limit of the part. Any attempt to redimsion them to near the size of the part results in useless limits and the resulting toolpaths are useless. So the question is can MADCAM set up a tilted rotary axis? I am using a 3 axis router with B slaved to Y, so need to use A to run the rotary. I would appreciate some detailed setup help.
    Mar 2004
    1661
    Re: setup for tilted 4th axis in MADCAM
    I have no idea. I haven't seen such a setup but there are some really funky machines running under MadCAM so I am pretty sure you can make it somehow. I think your best bet is an e-mail directly to Joakim and ask.
  1. setting 4th axis tilted for clearance
    By cruizer67 in forum CamWorks
    Last Post: 10-18-2018, 07:04 PM
  2. madcam 5 axis center of spindle axis
    By jeriesfacouseh in forum MadCAM
    Last Post: 10-21-2016, 03:09 PM
  3. Replies: 2
    Last Post: 03-12-2012, 12:21 AM
  4. Madcam 5 axis please
    By carbidecraters in forum MadCAM
    Last Post: 08-18-2010, 12:37 PM
  5. Madcam 4th and 5th axis
    By turmite in forum MadCAM
    Last Post: 02-21-2009, 06:37 AM
