how do you do setup a part to be drilled on your table if its bigger than your table? i basically have a tube that i need to drill holes in. the tube is 28 inches long and the table travel is 18.5 inches. the holes are 18 apart but are located five inches from one side of the tube. basically i need to figure out a way to indicate the end of the tube as it hangs off my table so i can drill the holes in the proper location. i have a couple of ideas but i want to see what you come up with.
thanks
Jerry
