I have a Leadwell CNC mill with a Mitsubishi Control and HA80NC-S servo motors. I had a problem with the servo motor on the X axis intermittently tripping due to overcurrent. It would using make a high pitch noise (like too much gain) and then it would fault out. I replaced the cable and connector this seemed to cure the problem for a few months. The motor started acting up again so I switched it to the Z Axis and the problem has followed the servo motor.
I am trying to take the servo apart far enough to blow it out good and see if I can buy myself a little time. I cant seem to get the case open enough. I haven't forced anything yet but it will open up about 1/16". I have the housing cover off of the encoder to loosen up the screws. Does the encoder need to come out? I took the 3 screw out of the flange but it doesn't want to lift up.
