587,761 active members*
3,099 visitors online*
Results 1 to 2 of 2
    Sep 2005
    41
    Separate 24V DC supplies
    In an industrial quality solution should I have separate 24V DC supplies for solenoid valve or relay actuation and other for inductive proximity switches? I’m posing the question because Bero proximity switches manual regarding cable routing specifies a minimum clearance or shielding to avoid interferences.
    Regards
    Dec 2003
    24220
    Although having separate 24vdc supplies for inputs and outputs may be considered ideal, I have never experienced a problem in using a common supply, Either use a common regulated 24vdc supply or if unregulated, make sure there is sufficient capacitance to keep ripple to a minimum.
    If you set up a common ground plate and take the power supply common's and all shields to this common point, then this should take care of noise sensitive devices.
    Al.
    Albert E.
