587,324 active members*
3,351 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > For Sale Only > Selling my FULL SHEET 150watt CO2 Laser
Results 1 to 2 of 2
    Nov 2014
    3
    Selling my laser from Southern California! Only $10,000!
    MORE IMAGES AVAILABLE HERE: https://imgur.com/a/zEYzAfM
    This laser cutter can accept FULL 4x8 sheets of material, and even larger (See specs).
    I have been using it for a few years making acrylic sculptures and the likes. It's a great shop addition; especially for large runs of jobs, or large format jobs
    The power supply will power a 150watt CO2 tube. There is currently a new 130watt tube in it. The tube was purchased in February, 2020, and has around 150-175 hours of use on it. It is rated for 10,000 of use.
    Comes with LAPTOP (!), software, water chiller, two exhaust blowers w/ venting tubes, air compressor... Everything you need to get up and cutting on the same day. It uses 120v, so nothing special needed in terms of power.
    It can cut all the standard things that CO2 lasers cut: Acrylic, Plexiglass, Plastics, Woods, Textiles, Leather, Paper, Fabric, etc
    It can not cut metal by itself, but if you were to add in a bottle of Oxygen for assistance, then you can get the job done.
    The only reason I'm letting it go is because I'm moving my business into a smaller location and need a smaller machine.
    It is located in downtown Fullerton. Message me if you'd like to come see it in action. Or if you have any questions whatsoever!
    -Brian
    SPECS BELOW.
    CONTROLLER: MPC 6525. USB Operated. Uses LaserCut5.1 software for sending jobs. Softdog dongle included.
    LAPTOP: Lenovo with Windows 7 and all neccesary software for laser cutting
    POWER: 120v single phase
    EXHAUST: Downdraft suction type. Vents are underneath material bed.
    MAX MATERIAL SIZE: 1400mm X Infinite (open on long ends)
    MAX CUTTING AREA: ~1280mm x ~2520mm (50.4" x 99.21")
    CHILLER: 120volts, CW-5000, adjustable temperature
    TUBE TYPE: Carbon Dioxide (CO2) gas
    TUBE SIZE: Length 65"
    TUBE POWER: Up to 150 watts (Currently has a 130watt tube installed)
    TABLE: Two-piece removable knife-blade tables.
    CHIP HOLDER: Slide-out drawers to catch chips and scraps for easy cleanup
    MOTORS: Dual steppers Y, single stepper X
    Nov 2014
    3
    Re: Selling my FULL SHEET 150watt CO2 Laser
    SOLD!
  1. Replies: 7
    Last Post: 03-04-2020, 08:07 PM
  2. Selling my PCNC 770 with a full shop of goodies
    By gyronikeleg in forum Tormach Personal CNC Mill
    Last Post: 01-24-2016, 03:20 AM
  3. China LIMAC Plasma machine cutting full size carbon steel sheet
    By limacchina in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 09-09-2013, 09:58 AM
  4. Stretch a Joe2006 to handle a full sheet?
    By Big S in forum Joes CNC Model 2006
    Last Post: 02-17-2007, 09:11 AM
