587,481 active members*
3,110 visitors online*
    May 2010
    307
    Seized Z-Axis?
    I have a new to me Lagunmatic 3516-SX I am trying to get up and running. It has a Dynapath Delta 40M control installed.
    After sorting out some faults related to the toolchanger, I was able to jog the X-axis but Y and Z would both fault out, saying no motion was detected.
    The DC servo have encoders amrhat are used by the control for position feedback. No linear scales installed.
    I swapped the Y-axis motor with the X and it worked, so then I started swapping servo amp cards. There were 4 installed (X, Y, Z, A) and I determined all but Y were good.
    I swapped all good cards to X, Y, Z and disconnected the coupler on the Z-Axis to allow the motor to spin freely. I was able to jog X, Y, and Z motor did spin.
    When I reconnect the coupler, I get the same fault on the Z-Axis. This leads me to believe the axis might be seized.
    Has anybody dealt with this before? The servo doesn't have a brake and the column has a counterweight. The counterweight is not tied down as far as I can tell (in fact it was jostling around during transport).
    My next step is to fully remove the Z motor and try to turn the screw manually but I was hoping for some advice as well.
    Thanks!
    May 2010
    307
    Re: Seized Z-Axis?
    Today I removed the Z motor and tried to turn the screw manually. I couldn't budge it. Not exactly sure what that means or what my next step should be...
    Jun 2013
    1041
    Re: Seized Z-Axis?
    Is there a break on the screw somewhere? Maybe the axis was bolted in place for transport. Seems strange it would be completely seized.
    Ben
  1. collet set screw seized.
    By 356911914 in forum Hardinge Lathes
    Last Post: 03-19-2013, 01:45 AM
  2. Seized end mill holder on a Sherline mill
    By spainguy in forum Benchtop Machines
    Last Post: 01-10-2011, 07:20 PM
  3. Seized Knee Gib
    By frontrange in forum Bridgeport / Hardinge Mills
    Last Post: 03-16-2010, 03:03 AM
  4. Pulling Seized Shafts
    By KSUsenior in forum Mechanical Calculations/Engineering Design
    Last Post: 04-07-2007, 04:03 PM
  5. Seized and broken bolt removal
    By Caprirs in forum MetalWork Discussion
    Last Post: 12-08-2006, 05:26 AM
