I'm looking for a "garage sized" cnc mill. I have a manual mill now.
Points of comparison that I'm trying to get information on, or am a bit unsure.
- As much Y travel, spindle to column as possible.
- ATC (So tired of changing R8 Tools), want a real one, not one of those table racks.
- Part locating tool in the atc (wireless?), Auto tool height
- Right angle attachment?
- Tapping?
- 4th axis?
- Spindle options (BT / CAT ?)
What I like about the Torus Pro: Y travel, Servos
For spindle to column, should I assume 1/2 of Y travel?
Novakon doesn't seem to have an ATC, although I did see this: NM200 ATC All Tool Test - YouTube but couldn't find it on their website. I did find the power drawbar, and the tooling for ATC, although it looks like TTS. Was hoping for something like BT30.
Both offer a BT30 spindle (talked to Khai about this via email), which is nice, but does either actually work like a standard bt spindle (pull stud). Will this work with the ATC (if it exists). I've emailed Khai about this, but haven't heard back. Yes, I'm impatient
I don't see much from Novakon on the auto tool height and part location, whereas i do from tormach, although it seems to be wired (which would probably be ok). Maybe this is usually just a third party purchase?
Not a clue on the right angle attachment. I have one for my current mill, and I do use it, and would like to continue doing the same operation on the new cnc. I can't see how this will work with an atc / pdb at all, maybe i'm just out of luck?
I'm guessing both do rigid tapping, so i don't think that's an issue
Both seem to do 4th axis, so if i need it in the future I know it's there
If anyone has any of the missing info, or can confirm any of my assumptions, I would appreciate it.
