Originally Posted by
radicooldude
I understood that there were x-ray radiation in the tv, so I took out the transformer carefully.
Did you wear a lead suit
Actually there is no radiation when the set is off and has been off for a while, the electro-magnetic radiation is from the HOT Horizontal Output Transformer, refered to as a flyback, is only when the set is running.
This Txfr can be identified by its construction, made from a large ferrite loop mounted next to a rectifier tube with a connector on top.
The connection on the side of the crt can store a charge for some time, but if it has been off for a while there should be no danger.
If the transformer you are looking at has steel laminations or steel cover, then it will be a mains transformer 50/60hz.
This one may be salvaged, but is probabally fairly low current.
Al.
Albert E.
