587,163 active members*
3,429 visitors online*
Results 1 to 7 of 7
    Aug 2010
    25
    Rustoleum Turbocrete
    I was trying to find most economical way to cast a base.
    Thinking about adding crushed granite to this in a 50/50 ratio.
    Any input would be appreciated.
    Thanks:idea:
    Jul 2006
    130
    Re: Rustoleum Turbocrete
    whats the viscosity on it like? One of the main issues way back when this topic first originated was getting a proper mix. 100% contact on all aggregate and retain the ability to degas.
    Aug 2010
    25
    I have found something I like better here.
    EpoxAcast
    35538
    Why not use regular epoxy? It's cheaper, and most likely works better than any of these alternatives.
    When mixed with stone aggregates, the epoxy only makes up 10-15% of the mixture.
    Try US Composites for inexpensive epoxy.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Jul 2009
    419
    I think that trying to save money on the EG side of things to be a waste of time and effort.
    You'd be taking the EG route to build a good machine. To get a good machine you'd need to spend hundreds or even an few thousands of money's on drive and mechanics. The money spent on EG then comes quite close to insignificant.
    Sven
    http://www.puresven.com/?q=building-cnc-router
    Sep 2009
    1856
    why not use a surface plate just get one from the factory pre drilled
    http://danielscnc.webs.com/
    being disabled is not a hindrance it gives you attitude
    [SIGPIC][/SIGPIC]
    Mar 2009
    39
    Specs on Rustolem seem close to what you see with an eg,from my quick scan.But specs require careful interpretation and never seem to tell you all you need to know.
    Compare with this Zanite.But the quick cure cold be a problem.I noticed in the video that the filler was fine and appeared ungraded.Typically you would use
    a graded mix of aggregate from;typically about 8-6 mm down to dust depending on use etc.Rounded river gravels will lessen viscosity with small loss in strength compared to crushed aggregate,provided each has the same strength.Cheap?The price I saw was $134 for 0.3 cuft.
    Not sure if you are trying to build a machine frame or fill an existing machine to improve damping?Filling an existing casting doesnt require a material with such stringent properties as a machine frame casting.
