587,801 active members*
3,476 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > rpm display on fanuc 10m controller
Results 1 to 2 of 2
    Oct 2008
    103
    Hi,All I have a victor v center-4 with a fanuc 10m controller and I notice when I go to the position screen at the bottom of the screen it has such things as feed rate speed rate and rpm.Every thing has something beside it but the rpm is this something that the manufacture of the machine does not use or is it a parameter setting that I do not have set?
    Thank You
    Jun 2008
    1511
    This is probably a parameter setting. I do not have the parameter list for the 10M control. Look in your parameter book for parameters related to "CRT/MDI, Display, and Editing". It should be listed in there. The bit label on my controls is (NOS).
    Stevo
  1. Fanuc O-MD prog ck display
    By yoshi900 in forum Fanuc
    Last Post: 10-15-2008, 11:35 AM
  2. Japanese display on Fanuc 12M
    By duccnc in forum Fanuc
    Last Post: 07-16-2008, 02:49 PM
  3. Fanuc 0i-TC Display Parameter
    By Hoonie in forum Fanuc
    Last Post: 05-20-2008, 07:44 PM
  4. Position Display on fanuc 6m
    By fredf1 in forum Fanuc
    Last Post: 10-22-2005, 10:08 AM
