587,349 active members*
2,948 visitors online*
Results 1 to 7 of 7
    May 2014
    19
    Router/Spindle Reccomendations
    I am almost done building my 1.5x1.8m CNC. Originally I planned to use my Bosh router as a spindle, but the mounting turned out to be very difficult.
    Which router can you reccomend? I want to cut mainly plywood. Is the Kress 1050 powerfull enough? Or should I get a wood Router?
    Makita Oberfräse Trimmer Einhandfräse RT0700CX2J Multifräse RT0700 im MakPac | eBay
    35538
    Re: Router/Spindle Reccomendations
    2.2Kw water cooled Chinese Spindle
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    May 2014
    19
    And the other options? Got a link?
    Jan 2005
    15362
    Quote Originally Posted by spooner777 View Post
    They seem to be having good luck with this Ebay seller
    infoshine15 | eBay
    Mactec54
    Apr 2010
    82
    I started with the Kress 1050, and while it worked well, I felt it underpowered. I got a Hitachi M12vc with precisebits collets and I like it a lot.
    Sep 2011
    281
    spindle is the best option. Porter Cable PC690 with Precisebit collets would work as well. the noise of any router is not good for your hearing, especially when running for 4-5 hours on one job. The spindle on the other hand is extremely quiet especially in the water cooled variety (I have never been around a air-cooled one)
    Colten Edwards http://www.cncsigns.ca
    Mar 2014
    22
    I have a Chinese 2.2 kw air cooled and it is pretty quiet.
  1. DIY Kit Reccomendations for 4x8 CNC Router
    By buddycot in forum Open Source CNC Machine Designs
    Last Post: 01-24-2022, 05:11 PM
  2. Chinese Spindle Liquid Cooling reccomendations
    By davespenden in forum Maintenance DIY Discussion
    Last Post: 09-05-2012, 03:12 PM
  3. Small kit reccomendations
    By eodjeep2000 in forum Open Source CNC Machine Designs
    Last Post: 07-14-2012, 09:05 PM
  4. CNC Conversion Reccomendations
    By TheGreenMachine in forum Bridgeport / Hardinge Mills
    Last Post: 12-08-2009, 04:54 AM
  5. Reccomendations
    By milford in forum DIY CNC Router Table Machines
    Last Post: 10-14-2004, 08:57 PM
