Originally Posted by
erazz
Hello All,
My company produces 3D moulds for composite applications. Currently we work on a Busselato Jet600 which is not our own and so I'm looking to buy a CNC router.
I need a router to mill MDF and tooling blocks (Sika 960-950).
I'm trying to decide between the following:
1) K2CNC KG3925-GTHK
2) ShopBot PRTAlpha 48 or 96
3) EZ-Router 4'-8'
4) ShopSaber 36x36
All with either a closed loop encoder-stepper motors or with full servo motors.
My main concern is accuracy. The Sika blocks reproduce accuracy errors and are a pain to sand.
Would the lower accuracy of machines 2 to 4 create problems here? Would running the machine at a slower rate help the accuracy?
Also, how much would an increase in Z travel affect the accuracy? The ShopBot setup looks pretty rigid while the K2 does not.
Any other suggestions besides the stated machines? (price < $10K)
Thanks for the help
I think you are confusing accuracy with smoothness of cut and though the two are connected, they are not nearly as connected as you think.
Accuracy would be telling the machine to move 10" and it moves 10". I think what you are looking for is a very smooth product after the machine has finished the carving routine?? Correct? This is accomplished by using a very small step over in your g-code and also using as large a bit as possible to keep the scallop to a minimum. If the machine has any, or at least very much vibration, you will want to run it slow enough to keep that from becoming a problem. The material you carve will also help determine the speed of your feedrates.
If I were going to advise you, I would need to know the minimum and maxium size of the models you carve. Get the smallest machine you can get by with and get that machine as heavy as you can. I have a machine that can cover a 4'X8' sheet of material with two heads but I don't need that kind of machine. I need one less than a 1/3 that size that is 3 times as heavy as the one I have!
Mike
No greater love can a man have than this, that he give his life for a friend.
