587,935 active members*
3,688 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Rotational axis (a) feedrates REALLY SLOW!
Results 1 to 8 of 8
    Feb 2008
    31
    How can I normalize the feedrates for the 4th axis with those of the the x,y,z axis? I'm thinking I'll have to either change the post processor or run a script on the G code afterwards to do some feedrate translations based on the A axis rotational method (degrees vs. inch movements)
    It's called Inverse Time Feedrate Coding. G93.
    There's a G code for ITF instead of Feed Per Minute (G94), and the F word is the inverse of minutes it takes to complete the move.
    For example G93 F2.0 will take 1/2 minute to complete the move.
    F needs to be in every move.
    35538
    What control are you using?
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Feb 2008
    31
    Using Mach3 for controller SW.
    I've just been adjusting the overall % feedrate offset downward until my other axis don't "trip" from being "rapid-ed" to quickly.
    I'd like to solve the problem instead of bandaiding it and get to work.
    35538
    I don't have mach3 here, so I'm going from memory.
    There's a checkbox in Config >Toolpath, and you need to enter the radius on the settings page.
    Note that the value entered for radius is from the center of rotation to Z zero. If you zero your Z on the surface of the cylinder, then enter the radius. If Z zero is center of the cylinder, then enter .001 for the radius.
    This should get your feedrates working properly.
    Gerry
    Feb 2008
    31
    I knew about the radius entry on the settings page, but will have to look at the other Config/Toolpath item. Any details would be great!
    35538
    Something like use feedrate for rotary axis. Should be self explanatory, on the right side near the top.
    Gerry
    Dec 2008
    4548
    It's a Mach3 setup thing... Go here and search for it in their forum and read a couple reply's....
    ArtSoft USA - Home of Mach3 and LazyCam
  1. Nakamura C-Axis Feedrates...
    By MaCroB in forum Uncategorised MetalWorking Machines
    Last Post: 05-11-2019, 05:52 AM
  2. 4 axis rotational cutting problem
    By kilrabit in forum MadCAM
    Last Post: 11-30-2010, 02:26 AM
  3. 4th Axis very slow
    By irv in forum Syil Products
    Last Post: 12-14-2009, 07:30 PM
  4. Vacuum hold-downs and rotational problem about the z axis
    By cpcp in forum Work Fixtures / Hold-Down Solutions
    Last Post: 12-08-2006, 02:02 PM
  5. home switch for rotational axis
    By xyz100 in forum DIY CNC Router Table Machines
    Last Post: 07-31-2006, 07:14 PM
