587,499 active members*
5,104 visitors online*
IndustryArena Forum > CAM Software > Vectric > Rotary Tutorial for Aspire & V-Carve
Results 1 to 8 of 8
Hybrid View
    I'm putting together a tutorial on rotary machining with Aspire and V-Carve. It is a work in progress that I hope to have completed by March 2010.
    http://www.222artisans.com/Rotary/RotaryTutorial.HTML
    Dec 2004
    1316
    Excellent resource, thanks rcnewcomb.
    Jason
    rotary on cut3d?
    I presume that cut3d works on the same engine as the other vectric titles. Then, may I assume that the rortary gadget could also be applied within cut3d? That would be neat.
    cheers, Maarten Visser
    Cut3D does not support a rotary axis.
    I've updated the tutorial and included examples for a Y mounted indexer. Please review these. When they are satisfactory I'll generate a set for X mounted indexers. Please review at:
    It looks like things are stable enough that I can start translating some of the Y axis examples into examples that will work with X mounted indexers. I hope to have that done by the end of next week.
    I enjoyed meeting others at Jim McGrew's Aspire gathering this past weekend.
    A copy of the PowerPoint I used for the talk on "Designing For Rotary" is available at:
    http://www.222artisans.com/Columbia/...gForRotary.ppt
    I tried to include material for non-rotary users so they could see how to take round designs and use them for flat machining.
    I did NOT use every slide. That would have been death by PowerPoint, but I wanted to be prepared for questions regarding some of the rotary gadgets.
    35538
    Thanks for sharing that.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  1. aspire and cabinetmaking
    By cabnet636 in forum Vectric
    Last Post: 06-28-2009, 02:50 PM
  2. Replies: 1
    Last Post: 03-13-2009, 09:36 AM
  3. Aspire!!!
    Last Post: 02-23-2009, 06:15 PM
  4. 15 minute Aspire?
    By bsimages in forum Vectric
    Last Post: 01-30-2009, 02:51 PM
