587,837 active members*
3,413 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Rotary Table Disabled after power on
Results 1 to 4 of 4
    Aug 2011
    7
    Cool Rotary Table Disabled after power on
    Hello,
    I have a 1998 Haas VF-4 with a rotary table. For some reason, for the past several months, every time I power off and power on the machine, the rotary table is disabled. (Parameter 43, 4th item down "DISABLED" is set to 1. When I enter a 0, then the rotary table is active and everything works fine. But, it is annoying that I need to do this every time I turn on the machine.
    Do you know why the machine disables the rotary table every time it turns on?
    Thanks for the help
    Mar 2010
    1852
    May be a stupid question, but you do hit "Write/Enter" after you change it to "0" right? Mine is set to "1" all the time and the axis still works though.
    Mike
    Two Haas VF-2's, Haas HA5C, Haas HRT-9, Hardinge CHNC 1, Bother HS-300 Wire EDM, BobCAD V23, BobCAD V28
    Mar 2008
    95
    there is another setting to change to identify the model number of the axis along with the 4th axis enable setting. not sure of the # but it is clearly labeled on the screen if you scroll thru it.
    Jul 2005
    12177
    I think the Model number is in Settings not Parameters.
  1. Adding a rotary encoder to a large Rotary Table
    By small.planes in forum Mechanical Calculations/Engineering Design
    Last Post: 04-27-2012, 07:27 PM
  2. CNC Rotary Table
    By KJ45 in forum Uncategorised MetalWorking Machines
    Last Post: 07-09-2010, 12:35 PM
  3. Rotary Table For SX3
    By DadHav in forum Benchtop Machines
    Last Post: 10-30-2008, 04:37 PM
  4. Rotary table
    By Piobaire in forum HURCO
    Last Post: 08-22-2007, 01:30 PM
  5. Useful for Rotary Table?
    By Ken Stuempge in forum Mechanical Calculations/Engineering Design
    Last Post: 02-12-2006, 04:16 PM
