587,424 active members*
3,931 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Rotary Manual Pulse Generator to ULN2003 Stepper Motor Driver
Results 1 to 2 of 2
    Jan 2007
    18
    Hello:
    Not sure where to post, so here I go.
    I'm looking to do the following;
    Rotary Manual Pulse Generator to drive (provide step and direction) ULN2003 Stepper Motor Driver that then drives one stepper motor.
    No computer, no arduino, no programming, min parts, simplest method.
    I want to turn the Rotary Manual Pulse Generator by hand, I want a stepper motor to rotate when the wheel of the Rotary Manual Pulse Generator is rotated.
    Turn Rotary Manual Pulse Generator clock wise, stepper motor turns clock wise, turn Rotary Manual Pulse Generator counter clock wise, the stepper motor turns counter clock wise.
    No movement of the Rotary Manual Pulse Generator means no movement of the stepper motor.
    Rotate, Rotary Manual Pulse Generator quickly, stepper motor turns quickly, etc.
    Full steps, no 1/2, 1/4, 1/8, etc. no speed changes.
    12 volt dc only for power.
    What one part can be used to connect the Rotary Manual Pulse Generator and the ULN2003 Stepper Motor Driver, to get the stepper motor to rotate.
    Roy - Pahrump, NV USA
    Mar 2006
    202
    Re: Rotary Manual Pulse Generator to ULN2003 Stepper Motor Driver
    ONE PART to connect the mpg and the ULN2003? With no programming? Unlikely.
    A 74xxx193 and a 74xxx138 might do the job, but could suffer from dither drift. ("xxx" could be "LS" or "HC" or whatever.)
  1. Function Generator to Stepper Motor Driver
    By omegasniper in forum Stepper Motors / Drives
    Last Post: 07-10-2014, 07:03 PM
  2. Need help with manual pulse generator
    By Jackal66 in forum CNC Machine Related Electronics
    Last Post: 10-26-2011, 05:52 PM
  3. Manual Pulse Generator for K2CNC
    By Mike Stevenson in forum K2CNC
    Last Post: 09-03-2009, 09:23 PM
  4. Manual Pulse Generator
    By widgitmaster in forum CNC Machine Related Electronics
    Last Post: 06-13-2008, 02:31 AM
  5. Manual Pulse generator?
    By phantomcow2 in forum CNC Machine Related Electronics
    Last Post: 07-24-2006, 04:10 AM
