587,645 active members*
3,067 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Rotary axis+off center?
Hybrid View
    Nov 2004
    85
    Is it possible to use axis substitution and run the Z axis say 1/2" off center of the rotary axis?
    How would one go about it?
    Thanks for any help.
    STephen
    Jun 2008
    372
    You will need to use a multiaxis toolpath to do this
    Nov 2004
    85
    What I am trying to do is cut 6 flutes down the side of a .7" round 4.4" long.
    I would like to use a bull end mill off center so I can get a different profile rather than a ball on center.
    My drawing is just drawn flat. Basically 6 lines drawn at an angle. Flutes are 1turn in 4.4"
    I have been using a contour tool path chaining the 6 lines.
    Using Axis sub in this tool path. I see no way of moving the tool over so it is not in the center of the stock.
    If I try a multi axis path it is looking for a surface as the drive so my single lines will not work?
    It looks like all the multi axis paths are looking for a surface?
    Does that sound correct?
    I could use the tool path I get with the cotour tool path and just set the Y axis over and run the bull end mill.
    I would rather use the verify just to see what my idea looks like, rather than run a practice part.
    Stephen
  1. A 5-axis CNC machine including a rotary axis
    By synthetiklone in forum CNC Wood Router Project Log
    Last Post: 07-12-2013, 09:32 AM
  2. Best way to center rotary table
    By Micro Milling in forum Uncategorised MetalWorking Machines
    Last Post: 12-31-2009, 03:50 AM
  3. Who knew? YUASA 5 axis machining center!
    By Kool Parts in forum Videos
    Last Post: 05-28-2009, 02:00 PM
  4. Replies: 2
    Last Post: 08-22-2008, 05:14 AM
  5. How to center a part on a rotary table
    By ryansuperbee in forum Benchtop Machines
    Last Post: 07-30-2008, 10:17 AM
