587,781 active members*
2,873 visitors online*
Results 1 to 7 of 7
    Jan 2007
    1389
    rigid tapping knob
    I dont rigid tap that much and frankly I dont want to screw up a brand new machine with a badcode.
    I have job that requiers 9 1/4-20 threads .50 deep through holes.
    we normally do this on the hand mill and a tapmatic however I have some time and was thinking of trying it on the vfs22.
    in the book they have the example set up as this.(using a 3/8-16)
    T3 M06
    G90 G54 G00 X.5 Y3.0 S900 M03
    G43 H3 Z0.2 M08
    G84 Z-0.6 R0.2 F45.0 (changed to 1/4-20)
    X1.2 Y-2.0
    etc etc
    I read there was an option for coming out faster and I need to make it normal? Also Peck tapping that sounds interesting due to the deep tapped holes.
    Someone care to give the proper code for rigid tapping and rigid peck tapping?
    Also do I need to worry about the coming out speed being faster?
    How fast can you rigid tap? I know the fadal is 2000rpm max but saw nothign about the HAAS and there manuals kinda are vague.
    Its a factory stock vf2ss with every option,
    Edit, the book didnt show the g99 on the G84 line but I know to put this in at least I think with the haas it needs to go in
    Delw
    Dec 2008
    319
    Quote Originally Posted by Delw View Post
    T3 M06
    G43 H3 Z0.2 M08
    X1.2 Y-2.0
    etc etc
    Delw
    Delw-
    Pull up the programming handbook on HAAS's site. It will answer both of these questions.
    http://haascnc.com/training/MillProgram_PDF/xmwb.pdf
    Tim
    Jan 2007
    1389
    Thats the one my wife handed me earlier she got it in class last week and said to read it. I didnt, I just told her to go out program it LMAO and she did. Gotta love sending her to school.
    I didnt see the max rpm in there yet I will look a tad later for it, again thanks
    I didnt try the peck tapping one yet.
    Jun 2008
    62
    Unfortunately, the Haas will not peck tap within one line of code. You'll have to create another operation with your 2nd depth in it.
    As for speeds, I tap 1/4 - 20 roll taps in aluminum ,75 deep blind holes at 1200 rpm, and back out at 3000. Set your reverse speed @ setting 130 HTH:cheers:
    Jul 2005
    12177
    Yes to peck tap you need to write multiple G84 lines with the different Z depths; it is not really peck tapping it is Repeat Rigid Tapping and you have to make sure both Settings (or Parameters, I forget which) are turned on.
    For rpm be lazy like me and use 1000rpm, it makes calculating the feed so much easier and if you want to come out fast put in the J value on the G84 line and leave the Setting at 1 (I think it is a Setting) so you have the choice in the code.
    Jan 2007
    1389
    Quote Originally Posted by Mic6 View Post
    Quote Originally Posted by Geof View Post
    That explains why I couldnt find anything.
    Geof I am lazy to I was just using the book as an example.
    Thanks guys
    Delw
    Dec 2008
    3136
    For rpm be lazy like me and use 1000rpm, it makes calculating the feed so much easier .
    Be even lazier , use G95 before the tapping code, Feedrate is the thread pitch
    finish the cycle with G80 and G94
    Then set any RPM and the pitch is still set
    Code:
    G95
    G84 Z-0.3 R0.02 F0.05 G99
    Z-0.4 (peck)
    Z-0.5
    Z-0.6
    G80
    G94
    The G80 G94 should be standard code before all toolchanges
  1. Rigid Tapping
    By Teps71 in forum Milltronics
    Last Post: 03-29-2016, 01:23 PM
  2. Replies: 24
    Last Post: 05-01-2014, 07:02 AM
  3. Replies: 13
    Last Post: 07-04-2009, 12:43 AM
  4. Tapping head or rigid tapping
    By Gregory_C in forum Syil Products
    Last Post: 10-18-2008, 06:49 AM
  5. Rigid tapping or tapping head
    By kentavv in forum Charter Oak Automation Support Forum
    Last Post: 09-24-2006, 06:08 PM
