After searching all over it seems to be impossible to find stock 8mm aluminum tubing.
I will make a .dxf if neccessary. What Im requesting is 5 tubes 3" long 8mm OD and 5mm ID to be made from 2024 or 7075. The OD will be going into a ball bearing to get an idea for tolerance-.005 at the most. I want a snug but not tight fit. ID tolerance can be +.005
No specific time frame requested but soon is prefered.
Please send quotes to [email protected]
Thank you,
-Justin Mathews
