587,354 active members*
3,720 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Reverse cutting direction
Results 1 to 4 of 4
    Apr 2003
    95
    I don't remember how to change the cutting direction from conventional to climb milling.
    I have put a profile toolpath on the outside of my part and selected climb milling but when I verify the toolpath it cuts conventional. In v24 how do I change it so it will cut climb mill?
    Thanks again,
    Eric
    Apr 2009
    3376
    You can use Contours to control direction
    Feb 2010
    0
    in the cam tree, right click on start point under the profile feature, select reverse direction. now you need to edit the profile feature nand change the parameter to left, or right to get the cut on the correct side of the profile.
    Apr 2003
    95
    Thanks guys,
    I was changing the direction at the start point but was not changing the parameter setting.
    It worked!
    Eric
  1. Axis will reverse direction on it's own!!!
    By Barefootboy4 in forum DIY CNC Router Table Machines
    Last Post: 08-29-2015, 11:24 PM
  2. Reverse Direction
    By timerie in forum BobCad-Cam
    Last Post: 09-26-2011, 04:29 AM
  3. Reverse Motor Direction
    By electric2u in forum Mach Software (ArtSoft software)
    Last Post: 02-19-2010, 06:46 AM
  4. Reverse direction?
    By HakBot in forum G-Code Programing
    Last Post: 11-19-2007, 11:30 PM
  5. Reverse axis direction?
    By saturnnights in forum Machines running Mach Software
    Last Post: 03-29-2006, 03:40 AM
