587,167 active members*
3,591 visitors online*
    May 2007
    781
    Removing the spindle pulley
    Is there a trick to removing the pulley (ER16 spindle) from the spindle?
    I have removed the setscrew but it is not moving, not sure how much force should be needed.
    Thanks,
    Andre
    It is an interference fit. I recommend heating the pulley (propane or butane torch) while using a pulley extractor.
    May 2007
    781
    Re: Removing the spindle pulley
    Yep shortly after I posted I found the info about it being a shrink fit.
    A little heat and I did not even need the puller just a leather glove, it lifted right off.
    Thanks,
    Andre
  1. Removing Pulley from Gear Box
    By JMFabrications in forum Haas Mills
    Last Post: 08-11-2015, 04:35 PM
  2. Help removing the motor pulley on a boss 5.
    By Steve_Watkins in forum Bridgeport / Hardinge Mills
    Last Post: 12-30-2014, 07:27 AM
  3. Help Removing Stuck Motor Pulley
    By ImagineRobots in forum Benchtop Machines
    Last Post: 09-17-2013, 04:04 AM
  4. Removing pulley from Taig spindle
    By warpedmephisto in forum Taig Mills / Lathes
    Last Post: 04-02-2006, 10:53 PM
  5. How to removing a pulley from a motor ??
    By RotorRouter in forum CNC Machine Related Electronics
    Last Post: 11-13-2005, 02:32 AM
