587,158 active members*
2,890 visitors online*
Thread: Relays
    Jan 2018
    6
    Relays
    What is the best way to connect a relay to power a air solenoid with a external 12v power supply.
    Feb 2009
    180
    Re: Relays
    What machine do you have? If you have a CNC machine with Mach 3 and Gecko drive, Gecko has outputs for control of external devices. Some of the newer machines like Mill Turn have pre-wired plugs for those functions.
    Dec 2003
    24223
    Re: Relays
    Remember to connect a BEMF diode across the relay coil, there are fast versions of the previously popular 1n4002/7 now, it is the UF4002/7.
    I use the 4007 version as this covers all voltage ranges.
    What is driving the relay?
    Al.
    Albert E.
  1. 3 relays
    By Kammo in forum CNC Machine Related Electronics
    Last Post: 04-18-2015, 07:11 AM
  2. why do relays get hot
    By contactirfu in forum CNC Machine Related Electronics
    Last Post: 02-09-2009, 01:35 PM
  3. Relays
    By 1ctoolfool in forum Haas Mills
    Last Post: 12-17-2008, 11:33 PM
  4. relays
    By fourperf in forum Fadal
    Last Post: 01-15-2007, 05:41 AM
