587,328 active members*
3,303 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Regrind taper on Cat 40 tools
Results 1 to 4 of 4
    Apr 2006
    133
    We are trading our Haas HS1-RP for a Haas EC-400 with probe and full fourth axis. I am wondering if we can have the tapers on the Cat 40 tools off the HS1 reground. I know it would change the gage length. We never put old tools in a new spindle. But we have a lot to tools for the HS1. Other wise we will buy a new tool package.
    If anyone needs a HS1-RP. I think the HFO would be glad to deal on it.
    Jan 2008
    282
    Why wouldn't you use the tooling you have without regrinding. Shops move tools around to different machines all the time? I would think that regrinding would cause more problems than just using the tool holders unless they are spalled or warn out.
    JMHQ
    Lowell
    4826
    Yes I'd also have to wonder at regrinding the tapers and getting them perfectly concentric with the tool holding bore.
    I suppose that the original manufacturer has a perfect spindle to hold the taper shank while the working end of the toolholder is finish ground. But working in reverse would be an expensive PITA.
    Jul 2003
    1220
    Re: Regrind taper on Cat 40 tools
    Sorry for off topic.
    Hi wanting to contact Jerry (JWK42)
    Jerry, please sent PM if you are still on CNCzone
    Cheers. Kiwi
  1. MB-56 VA spindle taper regrind.
    By iMillJoe in forum Okuma
    Last Post: 12-08-2013, 08:57 PM
  2. Spindle taper chrome and regrind
    By tcom-frazzled in forum Uncategorised MetalWorking Machines
    Last Post: 11-02-2012, 01:24 AM
  3. Lot of 45 taper tools needs a home..
    By tnik in forum Uncategorised MetalWorking Machines
    Last Post: 10-03-2008, 12:27 PM
  4. Regrind toolholders
    By I.C.O.N. in forum Uncategorised MetalWorking Machines
    Last Post: 03-26-2004, 05:43 PM
